Read the Issue: Click for the full digital edition of the February 2016 issue.
Editorial :
A Purchasing Evolution
Washington Alert:
OSHA's Silica Rule Moves to OMB
CEO Journal:
Updating Our Reality
Casting Complexity in Conformable Tank:
Michigan's REL Inc. aims to improve natural gas storage with an aluminum casting produced via a modified low pressure permanent mold process.
Gaining Customers by Degrees:
Cast-in heating and cooling elements are crucial to a diverse range of temperature-based applications served by Cast Aluminum Solutions.
Converting a Sand System:
One case study shows how converting a steel casting facility's olivine sand system to a phenolic-based chromite/silica system requires planning, cooperation and tight controls.
New Alternative Low-Lead Copper Alloy Shows Promise:
C83470 is a viable option to produce castings that will be in compliance with the Safe Drinking Water Act or other standards requiring castings to be low in lead.
A Case for Low Pressure Sand Casting of Aluminum:
Low pressure sand molding holds a distinct combination of advantages for large aluminum castings.
Issue Date
