Skip to main content
A publication of the American Foundry Society
Subscribe Now
Modern Casting Magazine
  • Current Issue
  • Advertising
  • Industry News
  • Digital Issues
  • Photo Galleries
  • Columns
  • Classifieds
  • Subscribe
  • Casting Competition
  • Webinars
  • Find New Casting Customers
  • Send a Press Release
  • Event Calendar
  • Supplier Marketplace
  • Category List
  • Current Issue
  • Advertising
  • Industry News
  • Digital Issues
  • Photo Galleries
  • Columns
  • Classifieds
  • Subscribe
  • Webinars
  • Event Calendar
  • Category List
Casting Competition 2021
Casting of the Year
Casting of the Year
Front Subframe Engine Cradle
Magna Cosma Casting Michigan CCMi
(Battle Creek, Michigan)
Material: A365 (AlSi10MnMg) T5 temper.
Process: High-pressure vacuum diecasting.
Weight: 38.5 lbs. (17.46 kg).
Dimensions: 45.6 x 42.1 x 4.7 in. (1,159 mm x 1,070 mm x 119 mm).
Application: 2021 Acura TLX.
Newcomer of the Year
Lift Arm
Blue Diamond Steel Casting
(Pigeon, Michigan)
Material: 8620 steel.
Process: Shell casting.
Weight: 167.6 lbs. (76 kg).
Dimensions: 46 x 18 x 10 in. (1,168 x 457 x 254 mm).
Application: Structural casting for Bobcat’s R-series loaders.
Best Casting Conversion
Best Example of a Casting Conversion
Magnesium Door Upper Beltline Reinforcement Casting
Meridian Lightweight Technologies, Inc.
(Strathroy, Ontario, Canada)/
General Motors LLC (Detroit)
Material: AM60B magnesium.
Process: Cold chamber high pressure diecasting.
Weight: 4.2 lbs. (1.9 kg).
Dimensions: 46.8 x 6.2 x 0.4 in.
(1,188mm x 157mm x 122mm).
Application: 2020 Chevrolet Corvette.
outstanding Achivement gyroid
Outstanding Achievement: Gyroid
Gyroid
Aristo-Cast Inc.
(Almont, Michigan)
Material: 356 aluminum.
Process: Printed investment casting shell.
Weight: 0.08 lbs. (35 g).
Dimensions: 4 x 1.5 x 1.5 in. (10.16 x 3.81 x 3.81 cm)
outstanding achievement bracket
Outstanding Achievement: Mounting Bracket
Mounting Bracket
Lethbridge Iron Works Co. Ltd.
(Lethbridge, Alberta, Canada)
Material: Ductile iron ASTM A536 Grade 65-45-12.
Process: Green sand molding, horizontally-parted.
Weight: 11.25 lbs. (5.1 kg).
Dimensions: 10 x 11 x 6 in. (254 x 279 x 152 mm).
Application: Planter’s fertilizer system.
outstanding achievement clamp
Outstanding Achievement: Clamp
Clamp
Waupaca Foundry –
Marinette Plant 4
(Marinette, Wisconsin)
ASTM A536 Grade 60-40-18.
Process: Green sand molding, vertically-parted.
Weight: 9.1 lbs. (4.1 kg).
Dimensions: 18.6 x 4.3 x 2.9 in.
(472 x 109 x 74 mm).
Application: Secures cable and tube of land-based wellbores for the oil/mining industry.
1695 North Penny Lane
Schaumburg, IL 60173
Tel: +1-800/537-4237, +1-847/824-0181
Fax:+1-847/824-7848
  • FEF
  • Contact Us
  • Privacy Policy
  • Site Map
