Tools to Improve Refractory Maintenance
Refractory maintenance, though vital, can often be a logistical and financial burden. To avoid unnecessary production loss, most facilities take on large-scale refractory removal and re-installation during annual maintenance shutdowns. But managers know how quickly these precious weeks fly by with crews struggling to complete as many maintenance tasks as possible.
Establishing an efficient refractory removal and installation process is important for maximizing productivity during these cycles, which is why many facilities employ innovative, specialized equipment that increases safety and minimizes downtime during refractory maintenance. From robotic removal to fast, ergonomic installation, here’s how facilities around the world are increasing refractory maintenance efficiency.
Demolition Robots
Getting foundry cupola furnaces up and running quickly is important to restarting production, but long cooldown times mean crews can’t even start descaling until well into shutdown. Additionally, descaling and debricking have traditionally relied on large crews with hand tools, such as jackhammers. This removal method comes with a number of drawbacks, including low productivity and increased risk of injury from equipment or falling debris.
Some cement facilities employ heavy-duty, remote-controlled demolition robots for descaling and debricking applications. These ruggedly designed machines can withstand extreme temperatures, allowing facilities to begin descaling operations earlier than with any other method. The operator remains outside the kiln, away from the heat and the risk of falling debris.
Demolition robots also offer an unbeatable power-to-weight ratio with the most innovative models performing on par with machines three times their size. Those in the 3,500- to 8,000-lb. (1,587–3,628-kg) range can safely drive across the cooler using the facility’s kiln access ramp––like skid steers or other support equipment––and aren’t heavy enough to cause damage to the kiln shell. Despite their compact size, industry-leading models can deliver up to 855 joules of hitting power at 550 to 1,250 blows per minute.
Top-tier demolition robots feature an innovative three-part arm, which requires less height to extend compared to a mini-excavator with monoboom––only 72–84 in. (182.9-213.4 cm) in most cases. This is ideal for work in kilns and other confined spaces. With a vertical reach between 15.8 and 21 ft. (4.8 and 6.4 meters) and a horizontal reach between 14.4 to 20 ft. (4.4 to 6.1 meters), cement facilities are able to fit the demolition robot to their specific kiln.
For one independent refractory contractor, adding a demolition robot to its crew significantly reduced overhead while increasing tear-out productivity. Relying on the robot’s remote operation, the company virtually eliminated falling debris injuries, which resulted in a reduced experience modification rate (EMR) and lower insurance premiums. The contractor also reduced crew size for descaling and debricking by 75% while achieving removal rates up to 33 ft. per hour (10 meters per hour). Reallocated crew members were then able to increase productivity on other tasks, leading to a boost in overall efficiency.
Hydrodemolition Robots
Hydrodemolition robots provide another efficiency-enhancing solution for refractory removal in tight spaces such as risers and transfer lines. This method uses high-pressure water jets to break up refractory materials without damaging embedded V-anchors, hex mesh, or the steel mounting surface, resulting in faster, more cost-efficient maintenance.
As with demolition robots, employing hydrodemolition allows facilities to keep crews out of the most dangerous situations through remote-controlled operation. Compact, highly versatile hydrodemolition robots can access confined spaces with some units able to operate just 14 in. (35.6 centimeters) from the surface to be demolished. Additionally, this water-based removal method eliminates silica dust while leaving a cleaner surface that doesn’t require additional sandblasting or power washing. This not only increases safety, it also eliminates a step to accelerate maintenance timelines.
Hydrodemolition robots also provide a significant productivity boost compared to hand removal methods. At 18,000 psi, hydrodemolition equipment can provide 100 times the productivity of handheld equipment, removing 9.5 cu. ft. of refractory per hour compared to just .1 cu. ft. with a 15-lb. pneumatic hammer. This productivity, paired with the robot’s ability to work on vertical, horizontal, overhead and curved surfaces without tiring, means facilities can make significant gains during refractory removal for a faster return to operation.
To maximize hydrodemolition productivity and overall versatility, many facilities and independent contractors partner with equipment manufacturers to provide solutions tailored to their unique needs. There are several hydrodemolition options available for refractory removal, but not all provide the same level of control and productivity. One important variable that can lead to gaps in efficiency is the distance between the nozzle and the refractory surface.
Simple automated setups, such as those used in risers that feature a rotating nozzle and stabilizing ring, might have several inches between the nozzle and the refractory surface. This distance results in a significant loss in power by the time the water reaches its mark, causing operators to compensate with a higher flow rate. A high-tech robotic system operating within .5 in. (1.3 cm) of the refractory surface, on the other hand, doesn’t suffer this loss of power, creating better removal rates per pump hour as well as better fuel and water efficiency. Additionally, this type of system allows the operator to set parameters, including the lance speed and angles, as well as indexing, to optimize efficiency.
Multi-purpose hydrodemolition robots can also be used in other areas of the facility for surface preparation and concrete repairs, providing better equipment versatility than single-use options. One such system is employed by a cement plant in Oklahoma for repairs on its concrete structures, including silos and foundations. The impact-free Hydrodemolition process eliminates microfractures and vibrations for a more durable repair in sensitive environments.
Refractory Installation
Increasing efficiency for removal is only half of the equation, though. To get production up and running again quickly, facilities also need to maximize productivity during refractory installation. Unlike removal, there is no high-tech replacement for a master mason, meaning installation can only move as fast as bricking crews. A bricking machine offers increased productivity and better ergonomics for fast, high-quality refractory installation.
Efficiency starts with bricking machine setup. Those constructed of strong yet lightweight modular aluminum components are easy to maneuver into the furnace and can be assembled in just 60–90 minutes by an experienced crew. Steel models might take six to eight hours and require additional support equipment. Modern bricking machines feature a pneumatic arch that raises bricks into place against the kiln shell and holds them there, eliminating the more physical aspects of traditional refractory installation. Additionally, the pneumatic arch system provides superior quality results that can extend the longevity of refractory by as much as 25%.
Bricking machines with a dual arch further increase productivity by permitting a second ring of bricks to be installed while the first is being keyed. This design features a cut-away section at the front of the arch that provides an unobstructed area to place key bricks. Machines without this feature force installers to try to find other ways to reach around the arch, reducing installation speed and, in some cases, quality.
Bricking machines from leading manufacturers allow masons to tailor equipment to fit their particular process for a more comfortable experience. Machines are available in a variety of sizes. Recently, a stair-stepped deck design was released that allows support equipment, such as skid steers, to drive under the machine for more efficient brick management.
Specialized equipment can also make maintenance more efficient in vertical vessels.
Custom-designed suspended platforms are being used by cement and other facilities as an innovative solution for brick and spray refractory installation in lime kilns, precalciners, cyclones, ISAMELT furnaces and preheater towers. These lightweight, heavy-duty metal platforms are erected inside the vessel and raised or lowered using manual or electric hoists for hassle-free maintenance and relining applications. Suspended platforms eliminate the need for complex scaffolding systems. Those featuring a modular design and pin-together construction can be set up in as little as two hours.
Additionally, suspended platforms provide ample surface area—and capacity—for personnel, tools and materials such as refractory brick, gunning equipment and other necessities. Refractory installation can progress faster since there’s no need to hoist supplies up and down; everything is close at hand and there’s plenty of room to move. This also reduces the physical strain on workers and the risk of falls, resulting in a safer work environment and decreased overhead.
From Start to Finish
When it comes to refractory maintenance, what comes down must also go back up before the job can be considered complete. Increasing efficiency throughout the process means facilities can start up production that much quicker. Working with specialized equipment from innovative manufacturers can greatly increase productivity, safety and overall quality of refractory maintenance. Whether it’s a robotic solution for removal, a custom-designed platform or bricking machine for installation or a combination of both, foundry facilities can revolutionize refractory maintenance by investing in the right tools.
